n2o
Old Dec 21, 2005 | 09:11 PM
InNeedOfAnEG's Avatar
Default n2o
hey guys, like i stated in previous posts...I am a noob to the vw scene, im a honda guy at heart...I had a few questions about the 8valve motor in the 86 jetta. I love nitrous, and i was wondering how the motor in the jetta would react to it? i wouldn't go over a 50-75 shot on it....anyway, What about a cam,etc,etc...Appreicate it guys.....
Grady
Grady
'91 Integra LS "under construction"
'91 Isuzu P'up ".........................."
Old Dec 22, 2005 | 01:40 AM
SkwervE's Avatar
realer than most
dont spray it..your going to run into a lot of problems..i know you prolly want power now and what not but just save your money and piece together a turbo kit...or build the motor then spray it..its probably not going to like it now..
*edit* swap a 12v in it and be done..
Old Dec 22, 2005 | 05:05 AM
BisquitMan's Avatar
Salad Tosser
He is correct. Don't waste your time with spraying. The stock compression ratio on that car should be 9:1, so you could piece together a cheap turbo kit and have a peppy little ride without having to worry about internal engine work. The biggest problem with that car when trying to make more power is the CIS injection, but all that can be addressed if needed. Otherwise swap a VR in there and let it rip!!!
Old Dec 22, 2005 | 05:11 AM
Pdubinator's Avatar
White girls suck;)
I agree, you could do mild turbo and be ok, its ultimately up to you tho. You can do suspension and rims while your figuring out what engine route you want to go
Old Dec 22, 2005 | 09:45 AM
SkwervE's Avatar
realer than most
make it sexy while you figure out what you are going to do..
Old Dec 22, 2005 | 09:54 AM
BisquitMan's Avatar
Salad Tosser
For the price of suspension and rims, he could turbo it.
Old Dec 22, 2005 | 10:43 AM
SkwervE's Avatar
realer than most
ya your right..just piece it together..
Old Dec 23, 2005 | 06:51 AM
Default yo
how hard would it to be to put the 95 1.8 turbo motor in it? I can lower it for free usin a sedaline torch . anyway, whats a typical motor swap go for? I know hondas are cheap, i just don't know shit about vdub's. Later
Grady
Old Dec 23, 2005 | 07:13 AM
BisquitMan's Avatar
Salad Tosser
There is no 95 1.8 motor, it would be a 2.0 8V. That swap isn't terribly hard and would be a better base for a turbo project. You could probably pick up what you need to swap it (Including motor) for under 500 bucks.
Edit, if you are gonna go through with a swap, just put a VR in there.
Old Dec 23, 2005 | 04:07 PM
Default ignition
i need an ignition switch,actually all wires under the dash for the '86,anybody got one? Why doesn't the car handle n2o well? Anyway, how muc would a vr swap be? how difficult,etc....
Grady
