Boost Question
Old Oct 23, 2005 | 03:52 PM
DD.'s Avatar
DD.
Administrator
Default Boost Question
I have a friend that has a gti. he was wondering how much boost he could SAFELY run on the motor. all he has done is a deverter valve, wastegate, and full exhaust.
Thanks in advanced
Old Oct 23, 2005 | 04:39 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
20 psi
Old Oct 24, 2005 | 04:50 AM
Kyle K's Avatar
vw/audi
The motor can take a lot more than the turbo. k03s limits arent much more than 1bar. If you go past that you'll see a much shorter life span.
Old Oct 25, 2005 | 04:18 AM
03gti1.8t's Avatar
got torque?
without adding fuel and timing, you can use a mbc or ebc and set it to about 12-14 psi. its best to get a chip because it will safely increase boost to around 18-20psi and add timing and fuel to compinsate.
[+]H&R cup kit[+]Neuspeed sways and front tie bar[+]Forge 007p[+]3" Forced-Motion turbo-back[+]Injen CAI[+]ECS Dog Bone mounts and STG 1 clutch/flywheel kit[+]Audi TT short shifter[+]REVO 4bar cai & turbo-back file w/ sps 3[+]SAMCO TIP[+]NGK Bk7eix[+]17" RS 4 Replicas[+]VDO[+]42DD A-pillar pod and clear corners[+]
anyone need gmail invites? pm me.
