Question about boost controlers!!
i don't think you're NOT supposed to use them, its just easier using a chip with multi-settings such as apr and the like to make sure you get the right amount of fuel with the extra boost.
anything runs a risk with a boost controller that doesn't supply proper duty cycles and fuel pressure. you can always play it safe and run rich as balls, but you will kill your performace and bust carbon for the rest of your life. apr and revo does some wonders from what i know. not sure, though. i don't know jack about the 20vt. i'm a 16v junkie that pushed cis-e to the wall and i'm using a homemade hondata ecu. run it rich and forget it.
If you have an APR chip can't you also get a boost controller? Does APR work as a manual boost controller? Get an electronic boost controller if you get one, IMO. I also suggest you get a boost gauge if you're going to be running more than stock boost. I'm sure the only reason they say you "can't" use a boost controller is in case you're running more than stock boost you'll have fuel issues, etc, like stated above.
My photography.
My photography.
