engine smoke:(!
Old Dec 3, 2004 | 08:06 PM
seanpoe's Avatar
n00b
Default engine smoke:(!
My engine started smoking for no reason(that i'm aware of) tonight. It wasn't smoking on the way home or anything, but when i got home, it started smoking. I know it could be anything... so any lead into the right direction would be great. Maybe the weather? its like 50degrees, so could that be it? thanks.
btw.... i have a 1998 vw jetta vr6
AIM - sPeOaEn
Old Dec 4, 2004 | 12:36 AM
OUTATIME's Avatar
OOKKAAYYY!!!
How bad was it smoking? A small oil leak might cause smoke when the oil burns up.
Old Dec 4, 2004 | 05:05 AM
emodsm's Avatar
red ass
where from? tailpipe? what coolor smoke? heavy blueish, grey or white sweet smelling smoke? more details man!!!
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old Dec 4, 2004 | 10:21 AM
seanpoe's Avatar
n00b
yeah, it did it again, and again, and again. my engine coolant was almost non existent. i thought it was a hose, but the smoke seems to be coming from the exhaust manifold, any thoughts?
it was a white smoke, that smelled weird...
AIM - sPeOaEn
Old Dec 5, 2004 | 11:18 AM
Subsonic's Avatar
don't be bullshittin!!!!
it is your head gasket..or the head warped... or block.... i would say more likely the first two than the third..I might be able to help you out hit me up in an email or pm
Got a VW? Hit me up!
M.E.C.P. certified custom stereo builder for hire
This Space for Rent
Old Dec 6, 2004 | 06:04 AM
BisquitMan's Avatar
Salad Tosser
+1
Highly doubt you warped the head unless you let it over heat real bad, and it is damn hard to warp a VR block. It is a cheap fix if you do it yourself, a gasket only costs around 30 bucks. But if you go to a shop, they will charge a lot for the labor, probably over 500. Also how many miles on your car, you might need to put on new manifold gaskets when the manifolds are taken off. Also VR headbolts are stretch bolts, so they are garbage once removed, you will need a new set. My suggestion is get ARP bolts, then you will never need another set. Hope that helps.
Old Dec 6, 2004 | 05:54 PM
seanpoe's Avatar
n00b
thanks for all the responses, but i found out it was a hose with a hole in it. i believe it was coming from the radiator. my engine coolant was low to non exihistent... i just cut a little piece off and stuck it back on. false alarm. thanks though.
AIM - sPeOaEn
Old Dec 6, 2004 | 06:01 PM
Subsonic's Avatar
thats good news... just keep an eye on your temp
This Space for Rent
