Almost there...Bagged s10
Old Jun 18, 2008 | 06:58 PM
DaMF'inBoss's Avatar
Originally Posted by killerMikeD
its either a York or sanden A/c compressor converted to pump air like an air compressor, alot of off road guys run these as well as mini truckers, instead of using electric compressors, the belt from the engine drives the compressor! - mike
Out of the two brands you mentioned, which is the best, and why?
A whole lot of thangs that go BANG!!!
Old Jun 19, 2008 | 04:29 PM
killerMikeD's Avatar
Lethal Fabrication.com
I prefer the York 209 mini or 210, because they are more common, easier to work on with parts aviability, and they have a oil sump, and essentially work like a regular shop air compressor, where as a sanden 508 does not, you have to run it like a Normal A/c compressor and use the PAG oil in it, although i believe it can pump to a higher pressure.
Lethal Fab
Old Jun 19, 2008 | 05:21 PM
WonUpRacing's Avatar
Clean ass truck man. I like going fast but have been tossing the idea around of getting a truck....decisions decisions
Old Jun 19, 2008 | 05:26 PM
blackonefifty's Avatar
Subscribed. I have an F150 that I wouldn't mind bagging .. maybe I'll learn a thing or two from this thread.
