HELP: Oil Leak on Rear of Motor (Ford 6.0L PSD)
FIXED -- Under Warranty
It was the ICP Sensor.
sweet
00 f250 ecsb
7.3 pstroke(92k miles
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
00 f250 ecsb
)2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
Yep, That definity looks like a rear main seall issue. I am having the same problem with my truck. I just got it back from the shop yesterday and I just noticed this oil leak around the RMS (refer to photo). Also, I noticed this bolt holes, should there be a bolt in the larger one? IF so, i assume this is the cause of the leak. ANy info on this would be a lot of help, thanks!
dude this thread is over a year old and the problem was fixed, did you read on what fixed his problem if it was the rear main seal it would not leak down from the heads
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
