Look at this truck, is this done right?
Old Mar 10, 2008 | 11:57 AM
Clint's Avatar
keyboard hardass
Default Look at this truck, is this done right?
It's got Dual transfer cases, but Arent you supposed to get an adapter and put the 2 together instead of doing this? I'm not sure but this just seems like the wrong way to do it...
Old Mar 10, 2008 | 03:22 PM
Clint's Avatar
keyboard hardass
Im thinking about buying it maybe, so any insight at all would be helpfulQ
Old Mar 10, 2008 | 03:34 PM
MonteCarlo31's Avatar
More pics to tell, those angles look a bit more then I would run. is the rear axle clocked at all?
Old Mar 10, 2008 | 03:50 PM
Clint's Avatar
keyboard hardass
yeah, quite a bit, ill post all i got of it
Old Mar 10, 2008 | 03:52 PM
Clint's Avatar
keyboard hardass
he's asking $3000, but I don't think I'd be able to use it for a daily driver
Old Mar 10, 2008 | 03:59 PM
Clint's Avatar
keyboard hardass
1977 chevy truck up for sale or trade. the truck is currently sitting on 44's. it has boggers in the rear and tsl's in the front. its got a 1 ton rearend and a 3/4 ton front end. im running dual transfer cases. the main case is a 203 which is ran into a swinging 205 case. its got a 350 4 bolt main. carter carburator with spacer. truck also comes with full msd ignition and a lunati cam. i also have spare doors for it as well.
thats his description of the truck
Old Mar 10, 2008 | 04:01 PM
1stGen7's Avatar
layin frame for life
them stacks are nice! look like he used vette sidepipes as stacks but it looks good
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Old Mar 10, 2008 | 04:03 PM
Clint's Avatar
keyboard hardass
thats what I like the least, probably the first thing I'd change
Old Mar 10, 2008 | 04:05 PM
1stGen7's Avatar
i had stacks on my s-10 was to loud so i took it off and put a muff under the bed and it fell off when i was off roading now its back to being stright pipe and im thinking about redoing the stacks
Old Mar 10, 2008 | 06:15 PM
jta's Avatar
jta
high five joel sucks!!!!!
If you go big most run a set up like that. With that being said that set up looks a little rough.
