Spray on bed liners.....
Looking at getting the F-250 (and possibly the TJ) the "Line-X" treatment.
Have any of you had any experience with spray on liners?
Is there a preferred brand?
What are the common pitfalls?
Thanks,
Cecil
Thanks,
Cecil
pitfalls: do it ur self spray and roll on kits, anything roll on sucks. I have done spray in on about 4 trucks myself "gator Guard" is what i use, if ur gonna load it up and drop things and have stuff slide around then I suggest Line-X by far.
I use the gator guard for trucks that dont get much use back there my s-10 which is tubbed and has a notch cover for my air suspension. And a few others, my step bros Titan which he is always throwing stuff in is pretty messed up.
Plus Line-x is also being tested/used as a a blast containment coating for buildings/walls. I seen on the news where they coated a cement block inside and out cinder(sp) block and droped it from atleast 30 feet up and it didnt break, with a simple application of line-X
Hope this helps- Mike
not tryin to steal your thread cecil..but im also looking for a place thats fairly cheap to do the inside of my TJ..Like around..$500?possibly?
00 f250 ecsb
7.3 pstroke(92k miles
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
00 f250 ecsb
)2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
They told me between $450 for nthe SD, and $550 - $850 on the TJ, depending on what all you want done (roll-bar, fender wells, etc.).
Line-X of Brandon gave me a price of $800 for the TJ abd $500 for the SD.
so do you have to be part of the club..?or just say you were refered..ive been asked to join the club..just havent done it...thanks cecil..ill check into them..!
00 f250 ecsb
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
00 f250 ecsb
)2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
i got mine done in my ranger and it cost me 420...i love line x it makes it alot better than drop ins and any do it your self kit...plus you dont have to do the work...but thats me i dont feel like messing up the bed of my truck and then be stuck with it
2002 ranger going off road
15" rockcrawlers and 31" bfg all terrains.
8kHID's
line-x
and much more
8kHID's
line-x
and much more
Line-X really is better than the others, especially the do-it-yourself stuff. I work for a company engineering travel cases, we do some line-x covered stuff. A 3ft cube trunk costs us $150 to get done, its pricy, but if you want it to look good, its worth it.
