sierra/silverado question
Old Feb 15, 2006 | 02:02 PM
BRET's Avatar
F*ck Tom Brady
Default sierra/silverado question
just purchased an 04' sierra 2wd and I would like to make it the same height as the z71's. Which lift (amount) should I use. Or should I try some good gas shocks first to see the height increase? Will "just" shocks raise the truck?
Old Feb 15, 2006 | 02:51 PM
2wdBlazer's Avatar
Vechicle Whore
I'm sure people will chime in and say don't lift a 2wd truck but hey, different strokes for different folks.
Shocks won't do it, The cheapest solution would be a body lift. I would say you probably need a 3 inch body lift. Even then you may not be high enough. Suspention lift would be next but I don't know what kind of options are out there for 2wd's.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
Old Feb 15, 2006 | 04:25 PM
jabtay's Avatar
Wheres the damn detonator
I do believe the smallest suspension lift for the 2wd is about 4". the rear is easy to lift the front is a little trickier. If you trust them you can use a 1" coil spacer
"The only thing necessary for the triumph of evil is for good men to do nothing."
"Si vis pacem, para bellum"
Old Feb 17, 2006 | 05:39 AM
CanTheWhales's Avatar
...Your Mom
2 inch body will give you the same look, but a 3-4 inch suspension lift will be cheaper, however, I don't think 2WD's need to be lifted...
Old Feb 17, 2006 | 05:51 AM
2wdBlazer's Avatar
Vechicle Whore
How do you figure a suspention lift is cheaper? YOu can buy a body lift for a hundred bux.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
Old Feb 17, 2006 | 06:04 AM
White93YJ's Avatar
well u could do lift spindles in the front, longer travel shocks, and blocks in the rear. i would stay away from a body lift if i were u. theres really nothin wrong with them, its just a suspension would be worth the extra little money spent.
2003 Ford F350 FX4 6.0L - White/2007 Front Clip
16" Custom Lift/Dual Resivour shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
ARP headstuds/EGR Delete/SCT Xcal3 Custom Tuned/RCD 190cc injectors/Some other stuff
Old Feb 17, 2006 | 06:12 AM
...Your Mom
/\ /\ /\ That's what I meant...
Old Feb 17, 2006 | 09:21 AM
jabtay's Avatar
Just do this - http://www.acmetruckparts.com/products/76039_300.htm Then put a 1" or so block in the back. These also come in a 1.5" and 2"
Old Feb 18, 2006 | 12:43 PM
2wdBlazer's Avatar
Vechicle Whore
I have a 3 inch body and 6 inch suspention. No problems with my body lift ever.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
Old Feb 19, 2006 | 07:01 AM
BRET's Avatar
F*ck Tom Brady
thanks that looks perfect
