Air suspension
Old Apr 8, 2005 | 09:18 PM
toolow's Avatar
bad ass truck i miss my extreme
Old Apr 9, 2005 | 01:13 PM
killerMikeD's Avatar
Lethal Fabrication.com
thanks
Lethal Fab
Old Apr 11, 2005 | 03:27 PM
Humpdatbooty's Avatar
Originally Posted by DANGERANGER
What size wheels? Do you want to lay frame? How fast and F.B.S.S. or Frt & Back?
Frank
Enhanced Concepts
727-638-4667
Ive got 16inch z71 wheels with 50 series tires. I dont care for a compressor, I just need a c-notch in the rear and 2 bags installed. Im on a single leaf spring and it rides like crap. I think i can do this myself, but i dont have the time and i dont have the equipment. I would guess $65 for each bag, $35 for brackets, and about $200 for a cnotch. Fittings and such would be a little extra, but i just need something simple.i dont know how much for labor though...
200-cnotch
65-bag 1/2 inch ports
35-brackets
15-air fittings
380 + labor?
when would be a good time to call?
Old Apr 11, 2005 | 08:15 PM
CRXSiR's Avatar
Fir Na Tine
killer-ya i like your truck but i wouldnt want a hole in the bed like yours..why is it necessary to do that...i wish i was more literate with this stuff..
00 f250 ecsb
7.3 pstroke(92k miles)
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
Old Apr 11, 2005 | 08:36 PM
toolow's Avatar
for the rearend.. it will poke threw the bed if not cut out properly...
Old Apr 12, 2005 | 04:25 AM
jchargu3's Avatar
Exactly, a lot of people get some sheet metal and cover it..
Killer's truck is my favorite 2nd gen (94-2004) S10... It's bad ass, and he's a cool guy that does AWESOME work..
He's still the only person besides my dad that i'd let even get a screwdriver near my truck to fix something.
Old Apr 12, 2005 | 04:26 AM
  #17 (permalink)
jchargu3's Avatar
200-cnotch
35-brackets
15-air fittings
380 + labor?
Also... Air line
Air tank
Valves
guages if you want them
what about this stuff?
What kind of bags are you going to run?
Old Apr 12, 2005 | 09:02 PM
  #18 (permalink)
DANGERANGER's Avatar
Shop Bitch
It all depends on how low you want to go or your purpose if you modify the bed. I just did an s10 for Diesel Audio/Radioactive on 20s did not touch floor because they wanted to go up and down and haul 14 12" subs in style.
Frank
Enhanced Concepts
727-638-4667
Old Apr 13, 2005 | 08:24 AM
  #19 (permalink)
Originally Posted by jchargu3
Also... Air line
Air tank
Valves
I would like to go with firestone airbags probably use 2600lb bags. I dont care for an air tank, i just will fill up at gas stations and at home... wait thats a dumb idea... No gauges and 6 dollar valves that let you use normal air compressors-kind of like a bicycle tire valve...? Basically I buy the stuff and you install it. I wouldnt need anyone to install this stuff if i were still in GA.
Also when should i call(hours)? Or better yet, visit your shop?
Old Apr 13, 2005 | 08:08 PM
  #20 (permalink)
Shop Bitch
Call any time Usually up at 9am usually better after 5or6 PM when I am not making noise.
Thanx
Frank
Enhanced Concepts
727-638-4667
