Lower
Old May 10, 2004 | 05:05 PM
UrbanRR's Avatar
Clutch it up!
Default Lower
What are the pros and cons about lowering a truck?
-thanks for your thoughts ahead of time
Old May 11, 2004 | 03:23 AM
SSpiro's Avatar
Errare Humanum Est
Pros: ? Depending on the look you want, lowering may help your look or style. Also modifying the suspension of a sports car helps with dynamics and handling.. however I really don't think this is the case with trucks.
Cons: Horrible ride. Rough, bumpy, rough turns and curves, floaty feeling, bunny hopping..
You don't lower a truck in search of a better ride, that's for sure. You lower a truck for the look or the style.
Old May 11, 2004 | 03:32 AM
xbroknpromises's Avatar
I <3 TR!!
^Not really a rough ride just depends on what you use to lower it. If you just chop the springs then yes, it will be HORRIBLE. My fiance has airbags plus shocks on his S-10 and I don't think the ride is bad at all. Its almost the same smoothness as my civic.
Old May 11, 2004 | 11:53 AM
UrbanRR's Avatar
Clutch it up!
thanks for the comments
USMC
In Iraq be back March 21 2008
AIM is Urbangixxer714
Old May 12, 2004 | 07:10 AM
DANGERANGER's Avatar
Shop Bitch
I have owned 5 lowered trucks and 2 bagged trucks. I don't know what you guys are lowering with (concrete bags?). If the proper parts and install are used then you get a factory ride if not better. As far as handling increased especially when lower profile tires and a little larger wheel is used. When you lower the center of gravity it helps Especially when larger sway bars are used in conjunction with lowering.
Frank
Old May 16, 2004 | 04:22 PM
24-7's Avatar
Civic Racing eXperiment
lower will look better, handle better and have less body sway while cornering. You have to watch where you go and check your groung clearences.
Old May 22, 2004 | 06:39 AM
Adam12's Avatar
Nohatch2000
as long as you dont plan on towing . pulling a trailer (unless its jet skis or something) or going of the pavement, basically everything a truck is used for youll be fine.
-Adam
________________________
Old May 23, 2004 | 10:07 PM
Jake's Avatar
dýsfuňctiønal
i hope u are lowering a mini truck? never any full sizes. completely defeats the purpose of having a truck.
FLeuro
TheCommision
Old May 25, 2004 | 03:44 AM
I <3 TR!!
Not really. Big bodies look really really good body dropped and lowered.
Old May 30, 2004 | 07:07 AM
Error's Avatar
Cone Killing Maniac
I'm lowered 4", and my ride is a LOT better than stock.
I'm dropping it to 7" and it'll be even better because of how I'm doing it, but that's my little secret
Error - CustomTacos.com Zaino Guru
