quick question 3sgte
Old Jun 25, 2003 | 11:13 AM
draco12369's Avatar
Question quick question 3sgte
Does anybody know if i could use a 3sgte head on a 5sfe block and what else i would have to do to put a ct26 turbo in that car?
Old Jun 25, 2003 | 01:31 PM
MR2driver's Avatar
not available
You can use a 3S head, and just got the stock setup from a MR2 turbo. Sorry I forgot the 5Sfe was twincam. The cams from a 3S definetly wont work in a 5SFE head.
Old Jun 25, 2003 | 01:35 PM
draco12369's Avatar
The 3sgte head will bolt right up to my 5s block, or do I need to modify anything, also how much boost can i run with the intercooler and the stock 5sfe pistons?
Old Jun 25, 2003 | 08:06 PM
MR2driver's Avatar
not available
it will bolt up, the coolant channels are slightly smaller on the 5sfe block, so to make it a true fit, you will have to bore the coolant channels, but it is not necessary.
You can run about 10psi safely with the correct tuning devices such as BTM and boost dependent FPR. If you dont have these things I would run no more than 6psi
Old Jun 26, 2003 | 03:21 AM
draco12369's Avatar
I already got a Vortech fmu and turbo supra injectors in the car but what is a btm?
Old Jun 26, 2003 | 05:57 AM
MR2driver's Avatar
not available
BTM is a boost timing master, it retards timing according to boost pressure.
Old Jun 28, 2003 | 09:32 PM
Adam82's Avatar
check out toyotanation.com under camrys and look for the wraith he is doing a hybrid 5s-gte the set up he is doing he's looking to get over 600hp with
