question on doing a rebuild on 2jzge in sc300
Old Oct 16, 2012 | 08:27 AM
blm182008's Avatar
Default question on doing a rebuild on 2jzge in sc300
I have a 94 sc300 it has a rod knock. I have a tt crank piston and rods and want to put them in. What do i have to do to put it in my motor and is it a good idea to do it cuz in the near future i want to boost the motor.
Old Oct 16, 2012 | 01:23 PM
BABILLARACING's Avatar
you can do it but the car will loose power due the lower c/r on the tt pistons while n/a
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Oct 18, 2012 | 03:50 AM
blm182008's Avatar
Losing power is fine. Am i goin to have to change the head gasket for the pistons to work
Old Oct 18, 2012 | 04:04 PM
kbprice's Avatar
Rocket Scientist
If your going to all the trouble to tear the motor down to replace rods, pistons, etc you might as well replace the head gasket too. A TT headgasket will work or just about any metal headgasket. You won't need a thicker one with the TT pistons.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Oct 19, 2012 | 10:36 AM
williamb82's Avatar
grease monkey!
tt pistons with tt head gasket will be 8.5:1 compression. stock 1st gen 2jzge compression is 9.2:1. tt pistons with n/a hg is ~9.1:1 cr, n/a pistons with tt hg is ~9.2:1 cr. up to you which combo to go with, but the tt pistons are thermal coated on the crowns stock, so DO NOT use a wire wheel to clean them. let the crowns soak in some pb blaster adn the carbo will just wipe off. using a wire wheel will scrape the coating off. the coating is on 7mgte pistons as well. not sure about 3sgte and 4agze but wouldnt be surprised that those are coated also.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
BLINGIN2001R6
Mar 30, 2013 05:15 PM
jmorando05
For Sale/WTB Toyota
6
May 5, 2012 04:09 AM
