safc help
Old Jan 3, 2012 | 02:52 PM
delSIsol's Avatar
Your Shit's Weak
Default safc help
have a sc300 with a na-t. trying to get a decent base tune on the safc.
turbe is a ar research td04 with a .60 intake and a 1.15 exhaust.
3inch downpipe with a 4inch hks super dragger exhaust.
550cc injectors
3inch fmic piping
thanks
Old Jan 7, 2012 | 07:02 AM
flubyux2's Avatar
Elitist Supra Asshole :)
And what wide band does it have?
Old Jan 11, 2012 | 04:10 PM
williamb82's Avatar
grease monkey!
id have gone with a maft pro. but as mentioned before, youll need a wideband in order to tune the afr's. id tune for 14.7:1 under vacuum, with maybe 16ish:1 at cruise. then under boost id run 12.5:1 afr until ~12-14psi then drop it down to 12:1 afr. im guessing your on stock 10:1 compression since you dont mention using a tt headgasket or swapping pistons. youll likely need to retard the timing some as well to prevent damage. the maft pro has the ability to adjust timing btw.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
3pc
For Sale/WTB Honda & Acura
Jan 11, 2007 03:05 PM
ridenleanback
Dec 23, 2006 03:50 PM
ridenleanback
Dec 23, 2006 01:37 PM
MissleMike
Dec 20, 2006 06:12 PM
