Supra running problems
I bought a 1987 7mge supra with a rebuilt engine. The engine harness is in rough shape and i am not running an 02 sensor or egr valve. My problem is that when I can get the car running it idles really low bouncing between 500-400 rpm until it finally just stalls out, or when I press the accelerator it dies on me. I feel as if this could be a fuel problem but im not sure, what would cause this?
Check the TPS (throttle positioning sensor) also, make sure the throttle bars that open and close the throttle body are adjusted right. The spring that pulls it back onto it self will wear out over the years, just fiddle with it and see if anything happens.
1986 Toyota Supra Hardtop NA (Maroon)
1989 Toyota Supra Targa CT-26 (White w/ Black accent haha)
make sure your vacume lines are routed and connected correctly
1.bmw 328i e36.
2.bmw m3 e36 clone blew up and sold
3.subaru brat... lmao sold
4.toyota supra turbo mk3 7MGTE under the knife
5. s13 dual cam hatch welded diff 5 speed current daily
1.bmw 328i e36.
You probably will with no o2 sensor, u sould get one of those first is it a gte or ge?
ge, i need to get my hands on a new wiring harness also because i believe the 02 wire was removed, and i have pacesetter exhaust headers back so the 02 sensor was moved
