1982 toyota corolla
Old Nov 18, 2010 | 07:03 AM
jdmasfck813's Avatar
Default 1982 toyota corolla
i have a 1982 corolla just wana know some few things like what can be a cheap swap how can i lower it.. and its doing high ideling ever day and waste so much gas
Old Nov 18, 2010 | 07:55 AM
threeteecee's Avatar
I'd have to say there is no such thing as a "cheap" swap for your car....as far as high idle take a gander at your carb and vacuum lines. That 3tc that's in there is a very good powerplant to begin with....but Im a bit biased. LMK I've got a turbo set up for that engine
dropping it correctly...check out technotoytuning.com
Old Nov 18, 2010 | 07:56 AM
nos3tc's Avatar
3tcgarage.com will be a good place for you
82 toyota corolla 3tc turbo
82 toyota starlet-f20c in progress
Old Nov 18, 2010 | 07:57 AM
^^^ agree
Old Nov 23, 2010 | 06:56 PM
What motor can i put in the this car then for a swap??
Old Nov 23, 2010 | 07:25 PM
nos3tc's Avatar
they make a bolt in kit for 2rz
Old Nov 23, 2010 | 07:28 PM
nos3tc's Avatar
3TCGARAGE.COM • View topic - 2RZ 3RZ Cross Member & Trans Mount kit for 1980-83 Corolla
Old Dec 1, 2010 | 05:38 AM
a new problem my starter neagtive plug keeps on flying out on plung and stuff and wont start lol i have to keep on puting it back on how can i fix this lil problem
Old Dec 3, 2010 | 10:39 AM
You are more than likely talking about the trigger wire since starters ground through the block. There is supposed to be a plug with a clip on it to hold it in place...there really isn't much movement in that area so I don't understand why it would continue to fall off. You might have to get a little creative though buddy....good luck
