AE86 rear differential
i need another rear dif, i dont care if its open or lsd. did toyota use the same style differential in anything else? i dont mean with the ring gear, ill just re-use mine. but will another dif from something other than an AE86 fit? i am in desperate need of one. i cant afford the KAAZ that i want right now, so just an oem one will have to do.
welcome to the woderful world of owning an ae86. u could use a diff out of a 82-85 celica, but it has drum brakes and a taller final drive. but it will bolt in to get you buy.
you could also use a diff out of an sr5 corolla, but its weaker and has drum brakes.
if you want the same thing that u have right now then its corolla gt-s only.
so you broke the stock lsd already?
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
drift car eh? so its already trashed and crashed? only 4 lug option solid rear you have that i know of is the 79-81 mk1 supra. has disc brakes too. its a 7.5in rear instead of the 6.7in, and you can use the same lsd's as the 7.5in trucks, like the truetrac helica lsd i run in my mk2. good luck finding a mk1 in the junkyard though. tons of them ~7-10 years ago. none now.
Buddy of mine parting out his car this should help ya on what you need ... Here is the lnk : CorollaCarClub - whatcha want off of an 85' GT-S coupe?
The foundation of a good car club is based on the members themselves!
http://www.facebook.com/home.php#!/p...00001701434182
http://www.corollacarclub.proboards.com/
http://rinconrolla98.blogspot.com
http://www.cardomain.com/ride/3005626
