AgentAndy's IS300 project
Old Sep 26, 2010 | 10:00 AM
agentAndy's Avatar
more class than college
spool fast...er
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Oct 6, 2010 | 02:27 PM
TweeT91109's Avatar
Originally Posted by agentAndy
spool fast...er
....umm $100 spool vavles could be ur greatest freind
1986 Toyota Supra Hardtop NA (Maroon)
1989 Toyota Supra Targa CT-26 (White w/ Black accent haha)
Old Oct 7, 2010 | 08:09 AM
williamb82's Avatar
grease monkey!
baddest 1j? i know of 1 in miami making 4 digit power already, and armin just built his and even knife edged the crank. failing to see how its the baddest in the usa. bad ass, yes, baddest, no
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Oct 7, 2010 | 05:59 PM
B18C5-EG's Avatar
It's plenty capable of making 4 digit numbers. Knife edging the crank is in my opinion pretty dumb. The crank it'self only sits in maby half an inch of oil so the ability to cut through oil isn't that necessary. Then after getting it cut you have to get your entire rotating assembly balanced. Then it still doesn't stop windage and reduces it VERY minimally. It does however lighten the rotating assembly but in doing so sacrifices low end tq and revs fall quicker.
So with all that in thought would you really rather have your crank cut, shaved, polished, and then rebalanced and still not have any detrimental effect twards windage, or would you rather just buy a crank scraper, near completely eliminate windage, not have to get everything re-balanced, and just bolts right in.
Old Oct 8, 2010 | 06:03 AM
williamb82's Avatar
grease monkey!
depends on the goal. but honestly, for the 6m im building with webers, id like to get the crank knife edged, for the 7mgte im building, no. but both cars are totally diff purposes.
