ok another stupid question i guess...
Old May 6, 2010 | 09:00 AM
87mkiiin/a's Avatar
Default ok another stupid question i guess...
ok so i have three supras...2 with abs (both have r154 trannies) and one with no abs(automatic) now im swapping my 7mgte and r154 into my auto with no abs...what do i do about the clutch hardline that runs from the slave cylinder into the abs pump and then to the tranny? can i go directly to the trans from the slave?
FWD drifting is nothing but ass dragging..... Yeah you can do it but so what? no one cares, its still FWD..... If you wanna drift for real, go RWD, and let it all hang out<
Old May 6, 2010 | 10:40 AM
Boosterseat's Avatar
No Rice Here
OMG
The clutch line goes to the abs system?
No doubt thread of the year.
Old May 6, 2010 | 11:54 AM
williamb82's Avatar
grease monkey!
what drugs are you on? seriously?
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old May 6, 2010 | 03:17 PM
the t3d's Avatar
JT61GT powered...
oh come on....don't be mean. the clutch hard line is a separate line all together and does NOT tie into the brake system at all
-t3d
1987 Toyota Supra TURBO Hardtop
Auto. to R154 Manual swap
fully built 7MGTE
JT61GT powered....
Old May 6, 2010 | 07:06 PM
87mkiiin/a's Avatar
ok def. feel stupid now i just went out there and pull the little plastic thing aside and saw that it went down instead of towards the abs pump
<---jackass
Old May 7, 2010 | 02:54 PM
the t3d's Avatar
JT61GT powered...
it happens man. i installed my cam seals BACKWARDS some how a while ago. haha
-t3d
fully built 7MGTE
JT61GT powered....
Old May 7, 2010 | 04:34 PM
toyotiny's Avatar
hhhhmmmm. i think hes on to somthing. abs clutch for those learning to drive stick!you dont feel the car pulse on a hard brake slam,so if your learning to drive stick and dump the clutch it might feel smooth. could be the next big money idea!
THE WING MAN NEVER LETS YOU DOWN!
Old May 10, 2010 | 05:56 AM
williamb82's Avatar
grease monkey!
if you dont know how to drive a clutch buy a bleedback valve. it restricts the flow from the slave back to the master cylinder to keep you from being to hard on the drivetrain. forget what company made it now. but i have seen them. has basically 2 orfices, 1 is a 1 way valve so the clutch can be disengaged instantly. but when you let off the valve closes and forces the fluid through the tiny orfice.
