ok, another problem with my mr2
Old Jun 11, 2002 | 04:06 AM
MR-2's Avatar
Default ok, another problem with my mr2
ok, i bought a guadge cluster for my mr2, and a monster tach
i put the new cluster in and everything worked great,
then we took it all apart and put the monster tach on.
problem......
-the lights on the custer work,
-only the speedometer works,
-everything else is dead
-the monster tach works
-all fuses are good
wtf????
Old Jun 11, 2002 | 07:21 AM
MR2driver's Avatar
not available
What year car is the gauge cluster from? Since your car is a 91-92, you have to use a 91-92 guage cluster, if you use a 93+ guage cluster, nothing is gonna work correctly.
Old Jun 11, 2002 | 07:06 PM
MR-2's Avatar
it a 91 turbo,
the gudges worked great, then we took them out and installed the monster tach, and everything runs while on acc doesn't
"suuuuper mark to the rescue!!"
thanx
Old Jun 12, 2002 | 08:48 PM
MR-2's Avatar
ok, i got that fixed,
now here the new problem
my radio, domelights, clock, and turn signals don't work
this is not a fuse problem
this is all my MR2 is god for :monkspank:
Old Jun 13, 2002 | 07:04 AM
MR2driver's Avatar
not available
Check all your fuses, I have no idea which one would cause all of those things to not work, but it is most likely a fuse.
Old Jun 13, 2002 | 06:49 PM
MR-2's Avatar
al fuses are good,
damn this sucks
the way everything before got fixed,
i pulled all the fuses out, and put them back it,
so now these thngs don't work, i guess that i'll pull all the fuses and it might fix itself,
something else might break
Old Jun 14, 2002 | 06:49 AM
therainforest's Avatar
check relays and your car might have a circut breaker. also reset your ecu and try the car after that.
Old Jun 14, 2002 | 09:16 PM
MR-2's Avatar
how do reset the ecu?
Old Jun 15, 2002 | 07:29 AM
JapDanny's Avatar
Anti-Flag
Disconnect your battery for about 15-20min resets your ECU .
For some stuff to work then other stuff not to work I think somebody may have done a hack job on your wire harness .
Old Jun 15, 2002 | 12:41 PM
MR-2's Avatar
hack job?
