1jz swap problem, need help
Old Apr 8, 2010 | 09:09 PM
STORM's Avatar
Default 1jz swap problem, need help
hey my buddy has a 1jz into his s14, he had tech 2 do his wiring but is having a little bit of a issue upon start up, for the first couple mins or so if i rev it up it runs fine but after it gets up to temp. and i start to rev it, it starts to break up really bad an backfires idle jumps around. i tryed replacing the ignitor map ecu ....I dont know if this could possibly be a wiring issue or maybe his coil packs or possibly his tps can anybody help me out on this i would greatly appreciate any suggestions thanx.....
Old Apr 17, 2010 | 06:23 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
most likely the o2 sensor.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Apr 19, 2010 | 04:41 AM
flyspyder55's Avatar
check the coil packs to see if theres any cracks in the epoxy, clean them real good and look real close.
im not sure im reading correctly, is the car running map ecu?
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
