1jz breaks up a 4k
Old Nov 30, 2009 | 01:50 PM
crazygrk3's Avatar
Default 1jz breaks up a 4k
i got a problem with my 1jz at around 4k it just sputters and breaks up right when it goes to built boost
heres what i have done so far
new coil packs
new spark plugs
new coil pack connectors
replace one of the two cam sensor pins that were no good
checked inside ecu for burnt capacitors
took out plugs and cleaned them they were gaped at .30 i put the to .28
and i am getting code 12 which correct me if i am wrong is either rshared_pm signal or knock sensor
and about the ecu is a HKS ecu
the car wont rev past 4-4500k rshared_pm at idle and under load when driving
does any body have any suggestions that can help me out it would be greatly appreciated thank you
You Aint Making Power Unless You Breaking Sh*t!!!!!
BOOST IS LIKE A VAGINA ONCE YOUR IN IT YOU DONT WANNA COME OUT!!!!!!!
Old Nov 30, 2009 | 06:36 PM
kbprice's Avatar
Rocket Scientist
Check all your intercooler pipe connections and make sure there isn't a loose pipe someplace. Reset the ECU buy unplugging the battery for a few seconds. Lastly, make sure you don't have any vacuum hoses that may have popped off.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Nov 30, 2009 | 07:09 PM
1320 Engineering's Avatar
check to make sure you arent getting fuel cut, getting low fuel pressure, or running out of injector
1320 Inc./////
Call - 813-842-0505
Email Info@just1320.com
http://www.just1320.com
8602 Temple Terrace Hwy. C-14
Tampa FL 33637
4ws tuning
Boost Lab
Old Dec 3, 2009 | 12:58 PM
crazygrk3's Avatar
ok thanks alot i am gonna check fuel pressure and see wat i got
Old Dec 3, 2009 | 01:17 PM
tissimo's Avatar
so free reving it wont go past 4k? try an ignitor
98 Toyota Supra Turbo
92 Toyota Supra Turbo
92 Toyota Celica Alltrac
90 Toyota Celica Alltrac
Old Dec 4, 2009 | 08:06 AM
crazygrk3's Avatar
yea i wont rev pass 4 to 4500 rshared_pm at all you can look and it will just stay at 4k and just sputter and break up at idle and under load
Old Dec 4, 2009 | 08:17 AM
flyspyder55's Avatar
i'd check these... in order..
1. CHECK YOUR GROUNDS!!!!
2. ignitor
4. map sensor
4. cam angle sensor.
and i have no faith in modded ecu's unless they came with your motor.
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Old Dec 28, 2009 | 04:47 PM
bikeimports's Avatar
what was your problem? was it resolved
