MK3 supra problems
there is some stupid box that is either yellow or white depending on the year that when it self-destructs your tail lights will not turn on unless the bake pedal is pressed. its underneath the bulb access on the driver side tail light. as far as headlights go replace the dimmer switch as i had a somewhat similar issue with that.
I just got in from working on the suppy, and yes that darn yellow box was a problem was the problem. well actually it looked like it was changed before because the connector that connects to it had a burnt spot. so that yellow box is still good, but i just cleaned all the pins in the box and i also fix the part of the connector that was burn and now they all work.....wooo hooooo
there is another issue but i want to make sure something wasn't missed. so sty tuned
ok i got 98% of the known problems taken care of. so i was checking out the fog light wiring, and the previous owner cut the wire! man when i saw that i was hot. anyways i will try to fix this next.
