2jz twin turbo engine swap
Old Aug 21, 2009 | 07:01 AM
the new kid's Avatar
Default 2jz twin turbo engine swap
hey i have a 87 supra and i ma think of droping a 2jz gte twin turbo in it will it fit and do i need a transmission or will the one i have work thanks alot
Old Aug 21, 2009 | 01:08 PM
elcubanaso7mgte's Avatar
well because you have an 87 your gonna need either custum motor mounts or find a 90 and up supra at the junkyard and take the cross member with the round mounts. as of transmission u can use the r154 thats in your car assuming you have a turbo supra and thats just the basics your gonna run into a lot more problems than that. if your looking to make less than 600hp than your better off going with a 1j swap is much easier and cheaper to do than a 2j. also wether u go with 2j or 1j your going to need one that comes with a rear sump oil pan
Old Aug 25, 2009 | 07:36 PM
kingfisher's Avatar
Howdy Audi
An R154 bolts right up, but what exactly do you want to do with it? A 2J has higher potential for power but the swap can cost upwards of twice as much as a 1J swap. If you wanna drift I'd say go with a 1J, they rev to the moon and beyond
It was late one night, a few years ago, when I was walking through Union Square Park. I suddenly felt someone behind me, their hands over my eyes. When I turned in surprise, there was Bill Murray, his creased face leaning in close. Bill whispered, "No one is ever going to believe you," and then just walked away.
Old Aug 26, 2009 | 02:40 PM
flyspyder55's Avatar
i would also reccomend a 1jz. but the motor mounts can be sourced from bicperformance.com and the r154 does NOT bolt right up, neither does the W58. your going to need a JZ/W or JZ/R bellhousing. driftmotion (.com) sells them for about 250 i belive (new) otherwise you'd need a 1jz soarer or supra bell for hte r154, or if you have a W then you''d need one from an IS, SC, or NA mk4
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Old Aug 26, 2009 | 02:42 PM
your also going to need a mk4 throttle cable, a mk4 power steering line, if your goin with a 1jz (in which case you must buy a supra one or it will cost you much more in the long run) you'll need E fans and a water pump off another jz series motor.
soarer oil pans and pickkups do not work. feel free to call us at 352-816-2407 if you have any other issues
Branden Berger
352-789-0006
Old Aug 26, 2009 | 09:21 PM
nos3tc's Avatar
i have a nice 1jz for sale
82 toyota corolla 3tc turbo
82 toyota starlet-f20c in progress
Old Aug 27, 2009 | 07:22 AM
suspectsupra's Avatar
search on supraforums.com
Old Aug 31, 2009 | 08:33 AM
Boosterseat's Avatar
No Rice Here
+1 for what Flyspider said.
Old Aug 31, 2009 | 08:37 AM
No Rice Here
Negative, The r154 wont bolt right up. 2jz's, and 1jz's are almost exactly identical, just that one is missing a half liter.
Old Sep 8, 2009 | 11:07 AM
a10secstreetcar's Avatar
7m FTW... 2JZ = GAY
