tercel engine swap help
Old Jul 26, 2009 | 12:08 PM
rotarykidd's Avatar
ROTM February 2013
Default tercel engine swap help
need help with a 4efe or 5efe swap in my 94 tercel. anybody ever do one? when i search it just brings up 4efte or 5efhe, but im not lookin to spend that much on a tercel. does any one have a guid?
Old Jul 27, 2009 | 02:14 AM
whiteknight's Avatar
the knights will ride!!!!
its a direct motor swap except for the harness, go to TercelOnline.Com :: the foremost Tercel resource. :: and get in touch with a guy named GT-Revva. He can build you a harness if your not up for splicing wiring harnesses yourself. Add a higher flow fuel pump and a Fuel Pressure regulator and your done.
Old Jul 27, 2009 | 02:09 PM
rotarykidd's Avatar
ROTM February 2013
i thought the 5e was direct swap if you use the 3e brown feul injectors. im goin with the 5efe ive decided. the fuel pump i knew about. thanks for the info
