Mr2 MkII 2.2L no spark!!!
Old Jul 14, 2009 | 09:00 AM
theo8989's Avatar
Default Mr2 MkII 2.2L no spark!!!
I have tried to pinpoint the problem but would like some advise. Let me start from the beginning. I was cruising in Fifth gear this past friday when all of a sudden the voltage dipped a little and then the car shut off. Tried cranking it would not start. I got it towed home and started poking around. I notice the fused labeled Fl AM2 40a in the front was blown. I tried replacing it, with the igition in the on position the fuse was ok but it popped again as i tried starting the engine. The ignition main relay clicks when you put the car in the on position, but the fuse label ecu-ig 7.5 after the relay is getting no power, which in turn goes to the igniter and then the coil pack. So im trying to pinpoint what could be wrong: igniter, coilpack, relay? I have included pic of electrical set up with some labels to give you guys a visual. Any feedback would very helpful. Also nothing is melted, wires to and from the harness look good.
Old Jul 16, 2009 | 05:14 AM
williamb82's Avatar
grease monkey!
what you need to do is see what that 40 amp fuse powers. then unplug all those components 1 at a time. if it still pops after unplugging them all then you have a frayed/cut wire somewhere touching ground. look for any cut wires or melted wires etc... not if you say unplug the ignitor and the fuse stops blowing. you have a bad ignitor that is shorted to ground internally and it will need to be replaced etc...
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Jul 16, 2009 | 10:47 AM
christo4_99's Avatar
your fuel pump is probably shorting out
the way i see it,if you combine two words,like bull and shit...well,you know the rest
Old Jul 26, 2009 | 12:54 PM
vishal25pm's Avatar
my 92 mr2 2.2 died on me one night cruising at 50mph, towed it home and after a couple days figured it was the coil. replaced it and was on my way
i had no spark but had fuel and the timing belt wasnt broke.
Old Aug 8, 2009 | 02:29 PM
theo8989's Avatar
Thanks for everyones help.....found out it was bad igniter
Old Aug 17, 2009 | 12:26 AM
MR-2's Avatar
yea the igniter was my problem too
greg
91 MR2 Turbo
94 Supra NA-T
94 CBR F2
Nothing wrong with Miss. Hong Kong leaning on my Supra.....
Old Aug 18, 2009 | 09:43 PM
EddieG's Avatar
I am replacing everything when I start putting my 3s back together.
