lexus sc400 stalling issue (AUTO)
Old Mar 14, 2009 | 05:20 PM
kkracing's Avatar
Mr. King K
Thumbs up lexus sc400 stalling issue (AUTO)
The car drives fine for awhile then starts to choke as if no gas or power is getting to it. put the car in neutral an shut it down for 1min then start it back up an put it on drive then its fine for a while again pls help THANKS TR
Old Mar 14, 2009 | 05:48 PM
BoosTedEj25's Avatar
oneslowwrx
Fuel filter
Old Mar 14, 2009 | 06:10 PM
kkracing's Avatar
Mr. King K
Has this been an issue for the sc bro.I just bought the car too. Drove it back an this crap happens. I'll check it out...Thanks for you help
Old Mar 14, 2009 | 06:15 PM
jriggs's Avatar
is better than you™
sounds as if the tps failing
Old Mar 14, 2009 | 06:54 PM
kkracing's Avatar
Mr. King K
Sorry dont know what a (tps) is. Would you please explain. Thanks!!!
Old Mar 14, 2009 | 07:19 PM
jriggs's Avatar
is better than you™
o sorry
tps is an abbreviation for throttle positioning sensor
on my gs300 i've had numerous problems with it, my neighbor has had problems with his gs430's as well. it's a fairly cheap little part if i recall correctly, but you should get a code for it if it's going bad if i also recall that correctly
Old Mar 15, 2009 | 04:37 AM
kkracing's Avatar
Mr. King K
Thanks man I'll check it out.. I hope I didnt buy a lemon. when the car doesn't bogg it run's like a champ the v8 sounds nasty!! I'm trying to make it run normal then slap a twin turbo setup or something LOL!!!!!!!!! Well see. Thanks tho
Old Mar 15, 2009 | 05:49 AM
extatic002's Avatar
is an asshole
^are you stupid? low blinker fluid wouldnt cause his car to stall...VTak just wouldnt hit as hard duhh
nah but seriously id check the TPS like ^^ said
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old Mar 15, 2009 | 05:54 AM
RoadRacer's Avatar
Turn 7 at Sebring
Are you getting a CEL (check engine light)?
If yes what is the code?
Moving to toyota tech
Patrick -
Old Mar 15, 2009 | 08:20 AM
scnat's Avatar
TR Admin Alumni
in the dia. port under the hood, put a jumper wire from b+ to FP. this will tell you if it is the fuel pump or the fp ecu.
