~~~~need info on 1jz~~~~~~
Old Aug 25, 2008 | 06:52 PM
rodknock_racing's Avatar
TRD_hmong_racer
Default ~~~~need info on 1jz~~~~~~
looking to do a 1jz swap in a 91 supra turbo......need info on wiring......thanks.....STY
Old Aug 27, 2008 | 11:08 AM
agentAndy's Avatar
more class than college
lol.
google.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Sep 3, 2008 | 04:12 PM
TRD_hmong_racer
tried but no one seems to have a list of wat needs to be done n wiring......anyone find anything?????......lmk.....thanks....STY
Old Sep 3, 2008 | 10:07 PM
kanji1jz's Avatar
jza70r
get on supramania and you will find everything you need. and if you can't find it then hit me up. and we can discuss pricing if you would like assistance.
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
Old Sep 10, 2008 | 12:56 PM
boosthappy's Avatar
multi fuel
go to 935motorsports.com. they heve the harness and alot of other stuff, bicindustries.com has the mounts, all other stuff can be found on ebay. if you feel like dealing with it the stock 1j harness needs to be extended 16 inches and it will work on any mk3. 89+ you dont need motor mounts but i like the bic ones.
Old Sep 14, 2008 | 11:35 AM
TRD_hmong_racer
so ur sayin doing the harness is the same way as doin the harness for a sc300?????.....jus extend the harness n everythin will work????......STY
Old Sep 14, 2008 | 09:17 PM
tissimo's Avatar
no you will have to rewire the body plugs.
98 Toyota Supra Turbo
92 Toyota Supra Turbo
92 Toyota Celica Alltrac
90 Toyota Celica Alltrac
Old Sep 15, 2008 | 02:05 PM
TRD_hmong_racer
o ok....so the engine harness to the ecu only need to be extended n the body plug (rpm, speedometer, coolant temp, cei, oil pressure, etc.) will need to be rewired or tap into the 1jz ecu harness?????...correct?????.....STY
Old Sep 18, 2008 | 04:27 PM
TRD_hmong_racer
Old Sep 19, 2008 | 12:40 PM
Dylan JZ's Avatar
一番 King
J.Man!!
links are over on SM as previously said.
Enjoy following car culture? 'Like' our page: Shutokou Syndicate
Advanced Race Technology / The Boost Lab
JZA70 / BW S300/83-75 powered
7M FREE Zone
STP JZA70 001 c.'07
