20v silver top swap into ae86
Old Aug 5, 2008 | 05:45 AM
ej6driver's Avatar
flat black fury
Default 20v silver top swap into ae86
I need to know excatly how easy or hard it is to swap my 16v out for a 20V does it bolt to the t50 tranny does the clutch and flywheel work can i use the stock 16v exaust manifold till i get a header for it does the ecu plug right into the body side wire harness what is the worst possible sceneiro?
"Procrastination is like masturbation, seems like a good idea at first but in the end your only fucking yourself."
^^^still under construction
Originally Posted by Epstein
A full cage is for 1) requirements of sanctioning bodies. 2) actual roll-over / crash protection. 3) a place to hang your multi-point belts. 4) impress high school girls with your "race car".
Old Aug 7, 2008 | 05:36 PM
DouglasProbe's Avatar
Version 5
worst possible - still an easy swap, great results, lots of different routes available and end product still a fun stock motor that rocks in an 86. Using the flywheel and clutch from the 20v (212?) the motor bolts perfectly to the t5o and you can even use your old motors mounts. the two debated and difficult aspects are ignition and cooling. the exhaust manifold is easily reused from a 4ag after rewelding the end flanges. the 20v motors were fwd - when flipped longitudinally the original placement of the 20v distributor meets the firewall. additionally, the stock coolant intake pipe interferes with the firewall. the oldschool, tried and true - but highly controversial choice is to bang your firewall to the point of breaking a big ol hole and everything fits fine. the motor doesnt run with the body harness and ill explain how this affects your decisions in a minute. if you find the idea of beating your firewall to death offensive other options exist. I personally used a popular method that blocks of the rear coolant outlet and runs from the water pump reverse and out the front leaving the fewest hoses lying around. the method is available on forums.club4ag in the 20v section authored by mr john. i cant write anymore
go on club4ag and the tech notes detail the swap and problems
Old Aug 13, 2008 | 04:05 PM
agentAndy's Avatar
more class than college
what he said.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Sep 1, 2008 | 03:40 PM
TE31Rolla's Avatar
The Monster
Its pretty much straight forward, just need to figure out the wiring and cooling as mentioned above. I'm in Orlando which isnt to bad of a trip, but if you need any help. Feel free to shoot me a pm or give me a call at the number in my sig.
Danny
Monsters Toy Shop, The 4AGE specialist
