AE86 Help Plz
Car is a 1986 Toyota Corolla GTS with a 4AGE
Car starts with a bit of hessitation once its running it idles nicely between 1100 and 1500 but as soon as we drop the idle to 700-800ish it wants to die out.
we played with the dizzy alot and it seems the perfect timing is between teeth its fully retarded on one tooth or fully advanced one tooth back and i belive its 5 degree's advanced for it to run nicely.
when the car is running and you punch the throttle quickly it wants to stall but if u put the throttle on slowly it revs up nicely
Dry compression is good #1-155psi #2-160psi #3-170psi #4-170psi
the car is it failed aircare in 2006 due to a gas cap failure, the seller was a younger kid, the guy i bought it from told me the fuel pump had been changed aswell as the fuel filter, the throttle body also appears to have been changed.
the story i was given was that it drove but it was slowly loosing power then the old owner let his friends drive the car and it died, he had it towed back to his place and it sat there for a year while he tried to figure it out. as i said above, he said the fuel pump was replaced, which unless he is a mircle worker with a screw driver it aint gonna happen, them screws are so old and corroded on there im scared to take them off. what i think happened is he bought the car couldnt figure out what was wrong with it fiddled with a bunch of crap and gave up, according to the aircare slip it failed in early 2006and the insurance was up
sorry for the complete back ground im really at a loss every time we think we figured out whats wrong with it we find sumthing else that says its not it and we're back to square 1 again
any help would be greatly appreciated
Did you check the plugs, distributor? I sounds like a fuel problem though check your injectors to make sure they are clean
Pro-Noob
Pro is the opposite of noob... Im a noob
http://www.cardomain.com/ride/3088770
www.myspace.com/azantro
Pro-Noob
I would focus less on fuel pump, fuel filter - after you check fuel is flowing.... check out your distributor and plugs, obviously. But i imagine its rooted in your iac or that different distributor...any changes in behavior when motor is cold vs. warm?
