3sgte cam specs
Old May 11, 2008 | 10:35 AM
Alltracfreak's Avatar
Default 3sgte cam specs
can somebody tell me all gen 3sgte cam specs including caldina? and what can a stock 3sgte valve train handle??
Old May 18, 2008 | 05:12 AM
dohcvteccivic's Avatar
Old May 19, 2008 | 09:22 PM
SangH's Avatar
Gen2 cams ~235* Duration ~8.5mm max lift on both sides.
Gen3 cams. Intake cam has slightly longer duration, ~4-5*. Has slightly higher lift, ~.5mm. Also ~1.5-2* advanced. Exhaust cam is identical to gen2, except is 4.5* retarded (in relation to gen2 exh. cam position).
I don't know the specs on the gen4, but it doesn't matter since they aren't interchangeable. The caldina uses COP ignition, lacking a distributor (ergo, no notch on the cam) and uses an internal cam sensor.
-Sang
Old May 29, 2008 | 02:29 PM
christo4_99's Avatar
i have some 250s made by cat cams in begium...billet...
Inlet
Clearance 0.2mm
Valve Lift 8.80mm
Duration @0.1mm 250deg
Duration @1.0mm 232deg
Lift@TDC Without clearance 1.4mm
Exhaust 0.2mm
Clearance 8.80mm
Valve Lift 8.80mm
Lift@TDC Without clearance 1.40mm....kinda strange to me but the duration @ 1mm is the same as hks 272s
the way i see it,if you combine two words,like bull and shit...well,you know the rest
Old May 30, 2008 | 09:44 PM
i was just wondering wut i could use on a stock head i have supertech dual valve springs and titanium retainers im trying to get rid of need the money bad
