Hot start problems!!
Old May 1, 2001 | 12:06 PM
j0lt's Avatar
Well my latest addition is an 88 Supra Turbo. Not exactly a hot rod (yet) but it gets around.. I need something to drive while the RX-7 goes under the knife.
Anyway it needs its TPS set which is no big deal. What is a big deal though is its hot starting problem. Once the car is warmed up itll turn over but never catch. I can still push start it warm and it starts cold with no problem but the damn thing wont start on its own when its hot!!! Makes getting gas exciting..
Any ideas would be appreciated...
-j0lt
Old May 2, 2001 | 07:14 PM
TealTalon's Avatar
-j0lt
what are you planning to do?
are you gonna keep the supra? i am actually looking into getting a supra turbo? it is a stick?
please let me know thanx
Old May 3, 2001 | 01:32 PM
j0lt's Avatar
Id like to keep the car but Ill have to see how much time I have to work on it.
Im starting to think it may be a leaky or faulty injector. Or maybe something with the injector wiring. This weekend Im going to spend some time with it and try to clean things up a bit..
Its tough to push start an automatic! (Yeah its a stick.. )
-j0lt
Old May 7, 2001 | 11:21 PM
j0lt's Avatar
Originally posted by NosExtreme
well to me it sounds like your starter is getting heat sychned that will often cause that problem.
Youre probably right! After a little more research I discovered there is a clutch in the starter. And the symptom thats dying is when the starter turns but doesnt engage the engine. Ah-ha....!
Thanks for the idea.. Im going to personally support some local Toyota dealers parts department now..
-j0lt
Old May 9, 2001 | 12:19 AM
j0lt's Avatar
After 3 hours its pretty close to being cool again isnt it? And itll start warm if its less than that? That is kind of odd..
Unfortunately theres no way that I know of to test the clutch inside the starter. If replacing it actually works though Ill consider myself very lucky (and buy a lotto ticket or two).
Ill let you know if it works for me but it could easily be a couple of weeks. Im going to order a metal head gasket and maybe the HKS valve springs just for fun and install those..
-j0lt
