mk3 help
Old Feb 17, 2008 | 08:27 PM
Bt_sr20det's Avatar
Bt_sr20det
Default mk3 help
ok when i get on my car it starts to sputter at about 3k rpms and then likes doesnt go anywhere. any suggestions?
Old Feb 18, 2008 | 05:10 AM
RTA Supra's Avatar
RIP Kevin
plugs, boost leak, wires, cps, tps.........
Need more info on the car there
Looking for OEM Acura parts? PM me
GO BOLTS!
09 Civic Si
Old Feb 18, 2008 | 05:12 AM
J-Dizzle's Avatar
Still Addicted to Boost
lets start with spark plugs? fuel filter? vacuum leaks?
Old Feb 18, 2008 | 05:13 AM
J-Dizzle's Avatar
lol.damn all mk3 owners think the same.
Old Feb 18, 2008 | 05:14 AM
J-Dizzle's Avatar
well i know i had something similar with the 1G where it would miss at about 3500 getting into boost. It ended up being the Plugs.
Old Feb 18, 2008 | 08:12 PM
Bt_sr20det's Avatar
Bt_sr20det
ok thanks for suggestions but ok some more info its a 7mgte and i dont have any wiring problems it was runnning then i replaced head gasket then i put it back together and it does this now.but it is like the car does go anywhere when u step on it but if u don't let it go into boost it will pick up and go somewhat also there are not any vac leaks and i also just put new plugs in but i am gonna check tomorrow. i also have have a little crack on the intake hose on the turbo but it doesn't seem like it leaks. My friends car is actually doing the same exact thing also.
Old Feb 22, 2008 | 09:05 PM
BuDdafUccO's Avatar
AFM
Check codes. Go from there.
11.9@123
