2JZ questions
I need more cowbell
on
2JZ questions
HI i have a couple 2J questions.
1.What does VVTI stand for?
2.What does it do?
3.What 2j motor will work in a 90-92 MK3
4.What would i need to do to swap a 2j into a MK3
5.And what price range am i looking at?
6.Difference between 1J and 2J?
and finally
6.Is it worth it? (im sure it is)
Imma a noob i know a couple of things but not much when it comes to mod'ing a car. but if anyone could answer my Q's will be much appreciated. but yea im looking to do a swap for a MK3 supra (90-92) and i just wanna kno a couple things i need to buy to make the swap a sucess.
Thanks for stopping by.
2.What does it do?
and finally
2.What does it do?
and finally
2.What does it do?
and finally
3. If you're going to do a 2JZ-GTE swap into a MK3, you'll need the mid-sump pan from a SC300/Soarer or JZA70 or JZA80 Supras (Aristo cuts have a front sump pan that does not clear the A70 cross member) and you'll need JZA70 1JZ mounts if you already have the 'round' later style mounts for 89.5+. For a tranny either the Aristo A340E can be kept if you're an automatic car, or if 5-spd you can use the A70 R154 as long as you use the JZA70 bellhousing and clutch for the R154 transmission.
For the rest of your answers I suggest you do some research on this section to see what you are getting yourself into: Other Engine Tech (1JZ-GTE, 2JZ-GTE, Etc) - SupraMania
It is expensive an expensive swap, but even more if you are not mechanically inclined and are not comfortable with doing your own wiring.
BOOST LAB, INC.
95 Toyota Supra Turbo - 1000HP
http://www.TheBoostLab.com
TURBO SERVICING & SALES | FUEL INJECTOR SERVICING
GARRETT - BORGWARNER - BULLSEYE - HOLSET - 3K
TiAL - TURBONETICS - FULLRACE - PRECISION
Shop Forum | FaceBook | Website | Online Store
BOOST LAB, INC.
that is a question... which is better the 7m or the jz? i would think the 7m.. unles you had VVTL-I. i dont quite understand what it is exactly ... all i need to know was the acceleration on razor's 7th gen gt-s scared the livin sh*t outta me. gl with your engine.
Go to SupraMania - Powered by vBulletin . It is a mainly MK3 Supra based site and it will have a lot of the answers for your questions and then some plus the people are nice and almost always willing to help.
Like I said, go on that forum and read. It will all mostly depend on your budget.
BOOST LAB, INC.
BOOST LAB, INC.
I would hate to see how much a fast car would scare you then if a slow one scared the living sh*t out of you
BOOST LAB, INC.
BOOST LAB, INC.
I need more cowbell
on
thanks everyone i was up till 4am learning more about supras. but chances are im not gonna get around to doing it soon due to the im have a baby soon. but im still gonna some $$$$ on da side. thanks agn guys. also.... hey kirk how did u come across knowing so much supras? did you go to school? anyways i hope know as much as you do soon.
Looking for OEM Acura parts? PM me
GO BOLTS!
09 Civic Si
GO BOLTS!
09 Civic Si
BOOST LAB, INC.
BOOST LAB, INC.
