waundering if this would work
Old Jan 13, 2008 | 04:37 PM
gifford's Avatar
Default waundering if this would work
i havent really checked into that much yet but i was waundering if theres a way to fit an sr20 into an 86 without having to fabricate the engine bay to much
Old Jan 13, 2008 | 05:54 PM
B18C5-EG's Avatar
you need custom engine mounts, you will need to cut the cross member for the oil pan, knock out the transmission tunnel, cut the stock shifter hole 3 inches, custom wiring, custom driveshaft, stronger rear end, and eat many of cheetoes
Old Jan 13, 2008 | 11:11 PM
gifford's Avatar
haha thanks man i geuss i better go stock up on cheetoes
Old Jan 15, 2008 | 08:14 AM
williamb82's Avatar
grease monkey!
for the rear, find one from a 79-81 supra and rebuild it with a true trac lsd. same one that fits the mk2 supra diff fits the mk1 solid axel.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
