Theft Deterrent System
I need help, I picked up a 86.5 supra that had a thrown rod I put a diff. Motor in it. The problem that I am having now is it will only crank over (won’t start and does not have a tack signal). The car has anti-theft on it. How do I check it, reset, or by past it. I would also like to get the pin out chart for it. If anyone can help that would be very helpful. I would also like to find a pin out chart for the 86.5 ECU ver. a 90 ECU I know the stock 90 has a diff mapping and would like to use that ECU if I can.
