How to fix your Supra Technical Information List, tons of info/articles
Old Nov 7, 2007 | 04:33 PM
Kirk's Avatar
Boostaholic
Default How to fix your Supra Technical Information List, tons of info/articles
Here is a list of items I have been working on and collecting:
Wiring & Electrical
How to wire GM Boost Solenoid to Supra TT (AEM EMS)
How to wire GM IAT Sensor to Supra TT (AEM EMS)
How to wire AEM MAP Sensor to Supra TT (AEM EMS)
How to setup 2-Step on the AEM EMS (2JZ-GTE)
How to wire FJO Wideband with AEM EMS
HKS DLI Installation
MK3 SAFC2 Wiring Diagram
TH400 Dakota Digital Speedo Convertor Wiring Diagram
How to install HKS VPC on MKIV Supra
How to wire VPC and SAFC together
MAPECU-2 Launch Control Circuit Diagram
Dual Fuel Pump Wiring Diagram
94-98 Lamp(bulb) Replacement Guide
Toyota Radio Information
Rewire: Fog Lights Anytime Except Key Off
Q45 Throttle Body TPS Wiring
How to program keyless entry
Factory Keyless Entry Manual
TRD 10,000RPM Gauge Installation
Full Supra Wiring Schematics
How to build your own O2 Simulator
SC300: How to wire Turbo Timer
NA Supra: SAFC/SAFC2 Installation
How to Install an AEM 1101 EMS into OBD-1 SC300
Resistor Color Codes
Comparing Standalone Engine Management Units
How to Reset ECU
OBD1 to OBD2 ECU Upgrade
SupraStick V4 Wiring for 1JZ SC300 (Cruise Control Lever Shifting)
4L80 Transmission Wiring for Dakota Digital Speedo Converter
2JZ-GTE ECU Pinout
1JZ-GTE ECU Pinout
Mechanical
How the 2JZ sequential turbo system works
TPS Adjustment Procedure and Testing Procedure
Stock Twin Turbo Removal
Supra TT Single Conversion Instructions
Spark Plugs for 800+rwhp Supras
How to Remove TRAC PUMP and TRAC Actuator
C's Short Shifter Instructions (In English!)
Converting 1993-96 Supra turn signals to 1997+ style
Camshaft Removal and Installation
NA to TT Swap Tutorial
Greddy T78/88 Boost Creep Fix
Turbo Oil Feed to Block Adapter
2JZ-GTE Shimless Buckets Guide
DIY: Checking Main Bearing Clearance with Plastigage
DIY: Installing a Piston and Rod Assembly
GReddy 3Row Installation Manual (In English)
SC300: Walbro GS341 install
SC300: 1JZ Swap tutorial
NA Supra: How to set timing
NA-T Headgaskets and Compression Ratios
NA Supra: Coolant Bypass Mod
What should I do: 2jz swap, 1jz swap, NA-T?
What do I need for an NA-T conversion?
All about converters and locks
Diagnosing common problems in the MKIV
JDM Supra Twin Turbo vs. USDM spec Supra Twin Turbo
2JZ-GTE Vacuum Hose Routing Diagram
Fuel System Setup
Tire and Wheel Info
Differences between Bar and Plate and Tube and Fin intercoolers
How to Change Spark Plugs
General
2JZ-GTE Engine Control System Diagram
2JZ-GTE Underhood Vacuum Diagram
2JZ-GE Underhood Vacuum Diagram
MKIV Supra Kick Panel Fusebox Diagram
How To Read Diagnostic Codes on OBD1
Basic Engine Troubleshooting Guide
Detailed Turbo Information Spreadsheet (moreboost.org)
Weight of Various MKIV Supra Parts (moreboost.org)
Turbo charging basics
Technical Terms
MK3 Fluid Capacities & General Maintenance
Supra Wheel Fitment Guide
93.5-98 TT AUTO to 6 SPEED SWAP PARTS LIST
What is VVT-i
MK3 Handbook Online (.PDF format added)
MK3 Data Tag/VIN Decoding Information
Understanding the Vf signal
IS300 technical resources and Boost Information
Full Supra Twin Turbo Specifications
Year by Year changes and Production numbers for MKIV
LAST UPDATED ON 11/30/07
If you could like to Submit a tutorial, do so by clicking here and creating your own thread: Submit your own!
Any help is greatly appreciated!
BOOST LAB, INC.
95 Toyota Supra Turbo - 1000HP
http://www.TheBoostLab.com
TURBO SERVICING & SALES | FUEL INJECTOR SERVICING
GARRETT - BORGWARNER - BULLSEYE - HOLSET - 3K
TiAL - TURBONETICS - FULLRACE - PRECISION
Shop Forum | FaceBook | Website | Online Store
Old Sep 1, 2016 | 11:48 PM
So Tampa Racing reset the counter and mercy sakes! AUG 31 2016, Another record set for number of readers on Tampa Racing at the same time: 2,523!
What's Going On?
Currently Active Users
There are currently 530 users online. 1 member and 529 guests.
Most users ever online was 2,523, Yesterday 31 AUG 2016, at 09:17 PM.
Upcoming Events for the Next 14 Day(s) click here for the BEST listing of car events between Jacksonville and Miami...
https://www.tamparacing.com/forums/forum.php and scroll down
65 people are reading General car chat and you can too by clicking:
Guns & Ammo
Jan 2, 2017 03:33 PM
Billy
Subaru Tech
Feb 20, 2013 02:33 AM
birdmanlopy
Apr 9, 2007 09:26 PM
Cronic
Feb 21, 2005 10:04 AM
The Kyle
Drifting
9
Aug 20, 2004 02:33 PM
