Supra Timing Question
Old Sep 25, 2007 | 12:37 AM
3pc's Avatar
3pc
Default Supra Timing Question
Ok so Saturday night my timing belt decided that it was done. Pic At the Bottom on this post, and I'm not going to try to lie and say I was just riding around when it happened cause I wasn't I was ragging it pretty hard. O and its a 91 N/A Supra.
But anyway heres my question. Ok I changed my timing belt out and marked the cam gears and crank before I removed it. After I put the new belt on and re alined everything to the marks I made. The car cranked up and seemed to be running fine so I figured (stupid me for not checking) it was in time. I drove it around the block and it seemed fine, wasn't hesitating or sputtering.
It was however idling higher then it did before hand and running a lil rich. I figured this was due to the battery being disconnected for 12+ hours and thought that the ECU just had to learn its self (happened before). Didn't give it a second thought came home and parked it over night.
Well Monday I get into the car start it up and as soon as it cranked and began to idle I could tell right away that the timing wasn't right. But I had to be to work in 30 mins had no other ride and no time to check it I said screw it and went to work anyway. All the way to and from work I could tell that it wasn't right, that it had felt like it was firing before it should and was way to far advanced.
So once I get home I put a timing light on the car and from that I was running about 30 degrees advanced. So I immediately took it all back apart and redid the timing and set it to about 15 degrees advanced (what the manual says to set it at if I remember right). Well i started the car and it seemed to be running alot better and how it should. So I got the timing light again to check it again, well it was sitting at about 20 degrees advanced.
Ok no problem I say I'll just retard the distributor some to take it down. Well I start to retard the dizzy and get it to about 18 degrees, was low as I could go before it starting to idle bad and cut out. Well leaving it there I take the car around the block and its running great not idling high not running rich anymore and seems to have more power then it did before the belt took a sh*t.
Now that I've said all that my question is do you think running at aprox. 18 degrees advanced is hurting anything? Should I just leave it there or try to re time it and get it closer to 10-15 degrees like the manual says (if I remember correctly as I don't have one anymore)?
I absolutely hate timing and its one the few things that I'm not very good at when it comes to a car. So I want to get some feed back from ppl that have alot more knowledge on timing and supras in general for that matter.
Thanks for any responses.
Myspace
Old Sep 25, 2007 | 06:55 AM
BPU95's Avatar
the base production unit
i found an article that states you should not advance past 14 degrees (up to 14 if you use 93 octane). i will find the article when i got home from work
