MKIII Supra HeadGasket Help **ASAP**
Old Jun 1, 2007 | 05:28 PM
Gloveman1386's Avatar
**FAMOUS**
Default MKIII Supra HeadGasket Help **ASAP**
Anyone feel like helpin a fellow Supra owner with a headgasket?? Tell me how much cash you need or beer or whatever, we need this done asap, car fucked up today after buying it (shady person)
The person changed the oil and flushed the coolant right before he sold it, as he stated in the ad, then we drive it home and CEL comes on and super uber white smoke poors outta the exhuast and now the oil is creamy and the car is sluggish and overheating, I know its the headgasket, who can help me?? LMK ASAP
Warning:anticipation of next sig may cause heart failure.......
www.myspace.com/gloveman1386
Old Jun 1, 2007 | 07:15 PM
**FAMOUS**
no one?
Old Jun 1, 2007 | 07:31 PM
flyspyder55's Avatar
bring it to ocala and i'll do it
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Old Jun 1, 2007 | 07:48 PM
**FAMOUS**
As much as id love to take you up on that offer, we have no trailor and I know it wont make it there...... sux
Old Jun 2, 2007 | 03:35 AM
RTA Supra's Avatar
RIP Kevin
Where are you located? Do you have the parts?
Looking for OEM Acura parts? PM me
GO BOLTS!
09 Civic Si
Old Jun 2, 2007 | 04:22 AM
**FAMOUS**
We are in clearwater, we are purchasing the parts today.....
Old Jun 2, 2007 | 04:24 AM
**FAMOUS**
We are buying the head gasket, intake gasket, valve cover gasket, head bolts and a few other misc things (sealants and so forth), should this be good?? Do we need anything else in particular??
Old Jun 2, 2007 | 05:14 AM
RTA Supra's Avatar
RIP Kevin
Depends. Where are you buying the headgasket and bolts from? I would seriously consider going with a cometic headgasket and ARP studs if you plan on modifying the car. You can use a Felpro gasket if you really want to, but do some research on these cars and see for yourself about the troubles they have with overheating. The major problem is in the tq specs, but I'm assuming you don't want to do that stuff. That's probably why you're asking for help. You also have to remember, the car overheated........You REALLY need to take the head to a machine shop to make sure it's even a good head. Once you know that, have them resurface it. It's also imperitive to check the block surface. It's a big job for someone who's not used to doing it, and also can be costly if you don't have all the info the first time. Feel free to pm me or email me if you need anything. My email's RTASupra@gmail.com
Hope that helps,
Eli
GO BOLTS!
09 Civic Si
Old Jun 2, 2007 | 01:19 PM
**FAMOUS**
We work at Tyrone Mazda, we have a toyata certified tech there, he is doing a extensive diagnostic before we buy anything, but we will see what he says, he already has the head off the car and such, but he left for the day, we will know tomorrow or monday
Old Jun 2, 2007 | 02:15 PM
Idealsupra's Avatar
I Hate Fuel Cut
sometimes a toyota mechanic isnt good enough with supras honestly.
if he goes by the book you WILL have the same problem sometime down the road. quite possibly very soon.
you must RESURFACE the head and you should really use a cometic mhg an some arp studs torqued to around 85 ft/lbs.
theres lot of other little things but those are the main points. the block surface must be cleaned VERY well at the same time and check for cracks as they like to develop between water jackets...
