01 Toyota Celica Help!
Old May 16, 2007 | 06:19 AM
boostinb13's Avatar
Default 01 Toyota Celica Help!
Ok guys heres the deal.
2001 Celica GT
The car doesnt run to well. It seems as if there is a hesitation while accelerating. Like I press the gas pedal and you hear the engine working, but the RPMs and speedo are barely moving, then it kicks in out of no where (almost like a turbo). Gas mileage isnt the best either.
Air filter and spark plugs are new. No check engine light. Anyone have any idea what might be the problem? Thanks
Old May 16, 2007 | 08:27 AM
supra rick's Avatar
fuel pump, injecters i dont know id check them
have alot of supra parts if you need any
Old May 16, 2007 | 08:29 AM
J-Spec's Avatar
Clean your maf sensor that seems to be the problem.
Old May 16, 2007 | 09:35 AM
boostinb13's Avatar
I was thinking it might had something to do with my MAF. How would I go about cleaning it?
Old May 16, 2007 | 05:26 PM
J-Spec's Avatar
I know its two phillips screws and i use rubbing alcohol and a que tip works every time when i have that issue.
Old May 20, 2007 | 11:20 AM
boostinb13's Avatar
WOW that shit made a HUGE difference. It worked lika charm. Thanks for your help
Sabri
