shortening an ae86 strut case
Old May 8, 2007 | 12:52 PM
3tc power's Avatar
Default shortening an ae86 strut case
i will be using the sw20 agx's and i wanted to know how much to cut off of the case so i don't need a spacer. i was going with 50mm but i wanted to be sure before i screww up a good set of cases.
Rudo
Old May 8, 2007 | 06:06 PM
YOTA ROBERT's Avatar
yo wats good with the yota i just bought another ae86 bro clean for 600.00
Old May 9, 2007 | 06:43 AM
3tc power's Avatar
i'm taking it to real speed up in Clearwater to do some rearend and some suspension work.
Old May 9, 2007 | 12:56 PM
dfigte31yota's Avatar
you should get in touch with T3 bro. this cars gonne be 3tc/efi/boost right?
CANT WAIT! that bitch is gonna be bad
Old May 9, 2007 | 09:15 PM
djbomberto's Avatar
I would suggest Club4AG - Tuned Toyota Automobile Enthusiasts or Hachiroku.net
I would search those threads about shortening the case. They do have exact measurements, pics, and DIY's as well. have fun!
Old May 10, 2007 | 11:57 AM
DouglasProbe's Avatar
Version 5
3TCPower what suspension work are you having done? but to stay on point where did you get your agx's for and how much?
Old May 10, 2007 | 02:07 PM
3tc power's Avatar
DouglasProbe
i'm putting a ford 8.8 under her. i also got a coilover conversion kit from Qa1 and i will be using it for the rear. i will be keeping the 4link setup because it works how it is right now. here is the part# 765015 sw20 kyb agx adjustables...you can pretty much find them anywhere that sells shocks.
dfigte31yota
correct! 3tc....efi....boost.....35+ to be exact. there have been tons of haters in this forum in the past and i am building this car with them in mind. i had my run in's with supra owners and they talk a lot of shit. don't get me wrong i love those cars but some of the bitches are cocky as hell.....back to the topic. i will post the car up once it is done.
i found out what to do as far as cutting the strut case, i will go with 40mm and then use a 20mm spacer.
Old May 11, 2007 | 06:19 AM
williamb82's Avatar
grease monkey!
i used aw11 rear struts in the front of my 84 mkii. i used washers to space it up and cut the spring seat off and welded a new one on for the coilover sleeve. works great actually.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
