HELP!!! AE101 4AGZE into AE82 twin cam
hello boys,
i am doin a conversion for a friend,
well the engine fitted nicely, but have problems with
loom.
i used ae101 loom and ecu, i have downloaded diagrams for ae101
and ae82 and did everything as i think it should be.
the car cranks, and the fuel pump turns on ( so the fuel is there ) but
there is no spark and injectors are not sprayng any fuel.
i have connected ae101 Y connector (22pin) to dash loom properly, i only left out wires for AC clutch, exhaust temp lamp and supercharger indicator.
everything else is good, ecu does get power, all the relays work ( i think )
any ideas???
Thanks
Peter
loom.
any ideas???
Thanks
Peter
Hello!
I have a 4AGZE and I have same problem than you!
Could you tell me about the sollution?
I need your help realy!
thx
Attila
thx
Attila
hello boys,
loom.
any ideas???
Thanks
Peter
loom.
any ideas???
Thanks
Peter
