MR2 4age 16v INTO an SR5 AE86
Old Mar 14, 2007 | 10:19 PM
Rey's Avatar
Rey
Default MR2 4age 16v INTO an SR5 AE86
this is what i plan to accomplish eventually. I have the motorset. Now, does anyone have a link to a writeup that explains what parts are needed and what needs to be removed/changed/altered in order to make it happen?.. This is not a desperation post. I just want to plan ahead
Old Mar 14, 2007 | 11:16 PM
B18C5-EG's Avatar
When I got my shortblock i had to interchange the alternator bracket and oil filter adapter from my bluetop. Pretty sure thats it for the bottom end but dont quote me it's just what I KNOW I could give you assumptions all day but i'll save you the time lol.
Old Mar 17, 2007 | 05:21 AM
djbomberto's Avatar
i know for a fact you would have to get a the GTS Exhaust Manifold. I'll look up to see if there is anything else (prolly a bunch ) =)
Old Mar 17, 2007 | 08:17 AM
Rey's Avatar
Rey
i know the intake manifold is a must
Old Mar 18, 2007 | 01:33 PM
toyotajoe1980's Avatar
drifting in the rain
rey if you want i can get a write up of what i went through for my mr2 4ag carbed in to an sr5
SOLDfor sale::::ae86 sr5 converted to twin cam carburated
webers/ headers/ msd/ 4puck unsprung clutch/ 10000rpm tach
4 point harness/ custom exhaust/ custom camsSOLD
Old Mar 22, 2007 | 06:38 PM
well even better wanna buy a sr5 with an aw11 4ag w/ weber carbs, flowmaster exhaust, cams, 4-puck unsprung clutch, mr. gasket fuel pump and fpr, accell wires, msd 6al ignition, msd blaster coil, monster tach and all in great working order,.............
all that for just $5500
Old Mar 29, 2007 | 08:59 AM
dfigte31yota's Avatar
heyb toyotajoe could you send pics of the car?
Old Mar 29, 2007 | 04:06 PM
kantfadedisazn's Avatar
The Asian Pimp Daddy
club4ag they have everything u need rey i tried copying the link but its all the same just check out the site
vien at Adventperformance.com
Old Mar 30, 2007 | 08:41 AM
J-KiNG's Avatar
I know you also need a gts gas tank..or just a fuel pump. something like that...
Old Apr 5, 2007 | 02:53 PM
djbomberto's Avatar
You need to install a piolt bearing, if your running a mech.fan youll need to switch over the RWD water pump assy. if electric youll be fine. I dont remeber if youll need to swap the whole water line set,been a while since I took a hi comp apart).Youll need to either get a RWD manifold adaptor or youll need someone to cut,swap and reweld the FWD manifold to fit RWD configuration. Youll need to switch over your 16v flywheel unless you have a good ae92 clutch,its bigger. Itll run off the bluetop stuff but the injectors are high impedence so youll have to search here or club4ag for the info on how to bypass that. Im not giving out that info just incase I mess up and you blow the motor some how? other than that I think that covers the basics.
