turbo with fuel problems...
Old Feb 9, 2007 | 05:33 PM
ridenleanback's Avatar
Default turbo with fuel problems...
i have a corolla turbo and the walbro 255 fuel pump was installed. when i go to put in gas the gas meter doesnt really move at all even tho i know there is gas in the car?
ANYONE KNOW WHY?!
Old Feb 11, 2007 | 12:40 AM
Is there a sender wire going from the gauge to the gas tank?
How do you know it is still connected?-Bob
Old Feb 11, 2007 | 11:29 PM
Now that we know the wire from the tank is sending current, the next thing to check, is whether the original gauge/instruments have been changed, or maybe the sending unit is having problems.
Have you pulled the sending unit up out of the tank to see
if the float/rod/etc. is OK?-Bob
It's also possible that with a turbo, since the air/fuel must
be readjusted, that you are burning more gas than you once did.
Originally Posted by ridenleanback
i remember you, you were going to help me lat time.......i put 20 bucks in it yesterday and it goes up to half tank....i guess thats full but without the turbo 2 bucks used to full me upp. and when it gets down to quarter is when the light turns on.
Old Feb 12, 2007 | 08:23 AM
rasta's Avatar
Rasta Racing
It's most likely the float rod itself. The walbro purchased by ridenleanback was NOT the proper unit for the corolla. The pick-up for the walbro was on the opposite side of the pump vs. OEM(the sock was on the wrong side).. Due to being on a budget, the walbro was retro fitted to the corolla pump assembly. The fuel float rod was VERY close to coming in contact with the pump due to its modified location...
Old Feb 12, 2007 | 06:32 PM
It's getting easier now................pull the pump, bend the rod away just a little bit, so it clears, wiggle it around a little to be SURE it won't touch, and put it back in.-Bob
