2000 celica gts check engine light
Old Jan 20, 2007 | 07:27 PM
hyperforce3's Avatar
Default 2000 celica gts check engine light
I installed a K&N air intake on my 00 Celica GTS and my check engine light came on. I took it to the dealer ship and the said i should drill a hole in the intake and attach a tube from there to the vacuum switch? Ne other ideas of what could be wrong?
Old Jan 20, 2007 | 09:10 PM
BlackWind's Avatar
Requiem
that could be it. That or the filter element was over oiled and it fried ur plugs and dirtied some of ur sensors...
okay
Old Jan 20, 2007 | 09:47 PM
Boostin97SE-R's Avatar
Resident Asshole
my fiance's car did the same thing. Take your mafs out and spray it down with some crc mafs cleaner. let it dry and reinstall it. Also disconnect your battery before doing this to reset the code. We put in just a k&n drop in filter though not a whole intake. The computers on these cars are super sensitive and a complete pita. goodluck. if this doesn't help your problem try newcelica.org
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
Old Jan 21, 2007 | 04:33 AM
Big Chris's Avatar
tampa car scene
Check the maf sensor, they are super sensitive on those cars, my friend messed his up just changing the filter.
Old schooler.
Old Jan 21, 2007 | 02:50 PM
hyoctane's Avatar
Teh fun begins @ 6k RPM
I've had my AEM CAI installed on my GT-S for over three years without an issue, but its AEM's second generation. I know the first generation threw a CEL... It deals with the vacuum lines from the butterfly valve on the stock airbox. Do some searching on --> NewCelica.org - Complete 2000+ Toyota Celica Resource and you'll find your answer.
'01 GT-S 6-speed|Original owner
Old Jan 23, 2007 | 07:28 AM
JDMBlackGSR's Avatar
Gators Bitches!
I had the same problem with my injen when I had the celica.......it was the MAF sensor. All you need to do is take the black box off the intake, clean the sensor with a QTip, and reinstall. Then disconnect the battery for about 30 sec to reset and you should be good. Hope this helps.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
