Swap Toyota Celica Engine
Old Jan 8, 2007 | 06:03 PM
Ekim03's Avatar
Default Swap Toyota Celica Engine
Hello i have a toyota celica GT 1991 its a automatic, i want to put a M/T Engine... im going to put same year engine though or is it ok to put higher model like 92-93.....do i have to do the wirings.. im new to fixing and swapping engines im trying to learn thanks a lot.
Old Jan 10, 2007 | 03:42 PM
dragonsrage86's Avatar
hey man the guy you'll wanna talk to is named elsuperspic. he's somewhat of an expert on 5th generations... and i know he did an engine swap a while ago. heres a post of his gl!
https://www.tamparacing.com/forums/l...-sweetbay.html
Old Jan 10, 2007 | 06:35 PM
GT4SOM's Avatar
Feel teh rally bishes!
Meh I'm no expert but if I was to do that swap I would definately get the wiring harness from the new engine because your also swaping it from a/t to m/t. Should bolt right in if I recall, I would suggest just pulling the 5sfe out of another celica.
Oh yeah if you need any clarification feel free to search on celicatech.com. Forums are filled of info for celicas.
1992 GTS 3sgte from hell! // 1990 GT liftback Stock 3sgte
Old Jan 22, 2007 | 12:29 PM
If you are planning on going to a manual trans from an auto,
look at a car at a junkyard, and note all the things attached
to that trans. That tells you what you will need to buy, and
there is more to the story................
If your motor is bad, swap the motor first. Drive it while you are collecting the trans parts. Easier than doing both with pedal swaps clutch linkage, and more.-Bob
Old Jan 22, 2007 | 01:17 PM
Ekim03's Avatar
I already went to junkyard and i found a M/T i was thinking if it is ok to swap 92-94 M/T to a 1991 Celica GT, oh my celica is GT it ok to get a M/T to a non GT celica thanks for the advice guys...
Old Feb 9, 2007 | 08:56 AM
christo4_99's Avatar
if you wanna go with a turbo swap i am gonna have some of the stuff you need for it..and to boot i might want that auto tranny if it's good pm me
the way i see it,if you combine two words,like bull and shit...well,you know the rest
