ae86 need help
Old Dec 26, 2006 | 12:26 PM
lookslikeabum's Avatar
Default ae86 need help
i have a 87 gts coupe. when i start the car if i dont let the car sit for a while and push the gas the car wants to stall out then after about ten minutes of driving it gets a bad sputter and i can not figure out the problem if any one has any info it would really help.
Old Dec 27, 2006 | 08:14 AM
YOTA ROBERT's Avatar
is it fuelinjected or carburetor
Old Dec 27, 2006 | 08:28 AM
its fuel injected
Old Dec 28, 2006 | 06:47 AM
82RollaSR5's Avatar
Toyotas For Life
you dumbass its an 87 GTS of course its fuel injected. he didnt say anything about switching over. sounds to me like a fuel delivery problem clogged/broken injector, dirty fuel filter, dirty/rusty tank. i would check there first and then try to figure it out more
Old Dec 29, 2006 | 03:23 PM
djbomberto's Avatar
Old Jan 22, 2007 | 12:59 PM
Unhook the fuel line under the hood and see if it SPURTS!
or if it trickles. That will tell you if you have a clogged filter,
and some cars have more than one.
Where is your cars fuel pump located?-Bob
Old Jan 25, 2007 | 10:00 PM
82RollaSR5's Avatar
Toyotas For Life
IF ITS FACTORY. the pump is in tank. do what he said ti will tell you if you have a clog or not. if nothing comes out check your connections and fuse(i think it has one)
