Toyota Tacoma Question
Old Dec 19, 2006 | 12:32 PM
BRAVO34's Avatar
"THE PARTS GUY"
Exclamation Toyota Tacoma Question
I Have A 99 Toyota Tacoma And The Check Engine Light Came On. I Did A Dio On It And It Comes Up Egr Problem. I Took The Valve And All Hoses Off And Cleaned Them , Cleared The Code And 2 Days Later The Light Is Back On So Then I Replaced The Egr Valve Cleared The Code And Sure Enough 2 Days Later The Light Is On Again. What Else Can I Try? Any Ideas?
Old Dec 20, 2006 | 07:53 AM
kbprice's Avatar
Rocket Scientist
May be a egr temp sensor. Mine used to do that then I just put a resistor in the Temp probe plug and no more code.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Dec 22, 2006 | 06:12 AM
3tcturbo's Avatar
check the egr vsv.....its common on toyota's ....even the charcoal canister might be bad....get the code and ill find out what it will be....i work for toyota
