1jz 86.5 supra
I was hoping you guys might be able to help me out. I just bought an unfinished projectfrom a friend. It's a 1jz 86.5 supra. He really didn't know alot about the build as he didn't do any of the work, the work is flawless though.
As for the turbo. He said it is a garret gt30r. I just want to know if you guys can help me with the specs and what kind power it's capable of.
Casting numbers are
vin tag JEM020721
714 568 5003
Also
m24
.70a/r
55mm
Turbo is T4 flanged. exteranlly gated and pretty huge compared to the 15g on my civic. thanks guys
Casting numbers are
vin tag JEM020721
714 568 5003
Also
m24
.70a/r
55mm
being t4 i would think more, but idk.
pics?
pics?
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
pics of the turbo??
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
if the car is running correctly you should see high 300's with that turbo on pump gas. race gas and more boost your looking at closer to 425-475 depending on the complete set up and exactly how much boost. It really depends on what mods and how well tunned the car is. Also what is the fuel set up? I guess that would play a large factor as well.
do you have pictures of the car itself or the engine bay?
Heavy car with a 2.5L
yes tunned is correct HAHAHAHA just kidding kelly
anyhow that sounds about right its not a HUGE turbo so its not going to give you 700whp lol
but psifactor is right depends on ALOT of things...
i love threads like these "how much power with this size turbo"
doesn't help need more clues!!!
ok you were wanting to know what kinda power it (the GT30r) is capable of right???
go on Supraforums or Supramania - Powered by vBulletin or Google and look up GT30R Turbo
and read
and read
