Mr2 Roll Call
I need some PARTS!lol but bump it if you drive an MR2...dizzy,maf,coil and ignitor,hubs,rr brake caliper,fuel pump,chassis harness,misc piping from filter to intake,exhaust manifold,fuel pump relay, " " resistor pack, fuel injector resistor pack, a/c idle up valve,boost pressure sensor,shifter cables,oil filler cap,goose neck where the cold start sensor is,water pipng(engine),intercooler fan,x brace,and clutch....
i have an ecu,i need exhaust manifold,cv joints,hubs,drivers rear brake caliper,fuel pump,maf sensor,shift cables(if the n/a ones won't work)not sure about that,ignitor,coil(although a 5sfe coil works if you modify the wire end from it),distributor,tail lights and maybe a radiator...that's it lol
